Hi All,
I am in the last miles for FW remote update in my application.
I already manage to write data to the internal FLASH and now I am working on FW update. Currently I managed to download the new FW to the upper FLASH sectors (The lower sectors are for the current FW).
Currently I am trying (with no success) to burn the new FW to the lower FLASH (I run the IAP functions from the RAM).
I managed to erase the old FW(The lower FLASH), prepare the new data to burn (the RAM functions is running after I erased the FLASH) but, the IAP functions stuck after the FLASH erase.
Why the IAP functions do not work after I erase the FLASH(it stores at non erasable memory)?
I am working with LCP2136 with no additional external FLASH and uVision3.
Please advice Kobi
Have you remembered your interrupt handlers? When reprogramming the flash, you can't run _any_ code from flash!
If the interrupt vector table is mapped to flash, or any of the interrupt handlers point to a routine in flash, you will get into big troubles quite quickly.
My interrupt vector is mapped to the FLASH but, I disable it before I run from the RAM. All the code that required for the burn, I run from the RAM.
The code that runs from the RAM is: All the prepare functions for the IAP. Init CPU. Burn routine.
Kobi
