I NEED THE PORCESSOR TO RUN AT 82MHZ BUT THE XTAL IS 13>7242MHZ
HOW DO I PROGRAM C TO GET THE CODE FASTER?
I LOOK IN UVISION AND CHANGE THE FREQ BUT IT DOESNT MAKE CHANGE IN CODE! HAVE I GOT A BUG?
What processor ? What crystal ?
Where in uVision did you change the frequency ? In the target settings dialog ? That doesn't do anything. If anything, you'll have to change it in the startup file.
YES THE XTAL IS 13.&242MHZ YES I CHANGE FREQ IN TARGET AND IT DOESNOT DO IT DO YOU HAVE THE SAME BUG?
Please stop writing in ALL CAPITALS!
There is no need for it, It's hard to read, and it's often considered shouting - therefore, rude.
can handle 82MHz is the SILabs f12x/f13x. so that must be the one you use. look at PLL0MUl.
I LOOK IN UVISION AND CHANGE THE FREQ BUT IT DOESNT MAKE CHANGE IN CODE! HAVE I GOT A BUG? a) if you conmtinue SHOUTING, this will be my last post to you, if the caps lock key is stuck, get a new keyboard. uVision does not do diddlysquat when you cnahnge the frequence, that is a code issue i.e. it is YOUR job.
