How do you bring up the Configuration Wizard Dialog to edit your startup code e.g. Start_v2.a66 in the middle of a project ? Currently i can only edit it as source code.
When you select the file "Start_v2.a66" then look at the bottom of the file just below the horizontal scroll bar and you will find two tabs. Just select the tab "Configuration Wizard"
