I've a problem with the A/D Converter example. I modified the programm, so that I can scale the voltage and different LED are ligthing. Furthermore the voltage could be changed with the potentiometer. Now I have a problem, if I upload the to the board, I can't see anything of these funktions. Now when I try to debug, the program hangs on the SWI_handler. So the main funktion never can be achieved! Does anybody know what the problem is?
Timo
Hello , can i know which controller u are using ?
Board: Phytec phyCORE HD200 processor: Phillips LPC2294
Are you sure you have your interrupt table correct. Are you expecting to receive a software interrupt? What interrputs are you expecting to get? for example you could be getting a data abort interrupt, but because the interrupt table is incorrect, it is being caught by the SWI interrupt handler. I am assuming the the SWI interrupt handler is a loop as follows:
SWI_Handler B SWI_Handler
