inline \ MACROs
I want to avoid the CALL \ RET overhead of a certain function which is called only once in my program.
I understand the uVision compiler does not support the inline keyword (http://www.keil.com/support/docs/1755.htm), and I should use macros instead.
The problem is that uVision cannot step into macros when debugging.
Is there any good solution for this problem?
