A few days ago I encountered with strange program behavior, and the reason I found was compiler bug. The problem can be revealed after compilation of the following code:
double Variance(int Sum, unsigned long long SquareSum, int NumSmp); ... int ADC_GetSum(void); ... { ... double tmp; int NumSmp ... tmp = Variance(ADC_GetSum(), ADC_GetSquareSum(), NumSmp);//!! ... }
The line marked with //!! compiles incorrectly, i.e., the second parameters got corrupted before invoking Variance. Here is relevant lines from listing (*.LST) file produced by compiler:
48: tmp = Variance(ADC_GetSum(), ADC_GetSquareSum(), NumSmp); 00000034 F7FF BL ADC_GetSum?T ; T=0x0001 (1) 00000036 FFE4 BL ADC_GetSum?T ; T=0x0001 (2) 00000038 B401 PUSH {R0} 0000003A A802 ADD R0,R13,#0x8 0000003C 6803 LDR R3,[R0,#0x0] ; NumSmp 0000003E B408 PUSH {R3} 00000040 F7FF BL ADC_GetSquareSum?T ; T=0x0001 (1) 00000042 FFDE BL ADC_GetSquareSum?T ; T=0x0001 (2) 00000044 1C01 MOV R1,R0 //!! 00000046 1C0A MOV R2,R1 //!! 00000048 BC08 POP {R3} 0000004A BC01 POP {R0} 0000004C F7FF BL Variance?T ; T=0x0001 (1) 0000004E FFD8 BL Variance?T ; T=0x0001 (2)
One can see, that lines marked with //!! must be interchanged in order to correctly move content of R0..R1 to R1..R2. I've spent half a day trying to find error in my program. From the about window of IDE:
IDE-Version: µVision3 V3.23 Tool Version Numbers: C Compiler: CA.Exe V2.42 Assembler: AA.Exe V2.40b Linker/Locator: LA.Exe V2.42
In this connection, I'm afraid to use this compiler any further. I would like to know, is there any document which describes CARM errors (I have not found one on this site). Or what can people with rich experience in embedded software development suggest to me in this situation?
prototype of ADC_GetSquareSum() is defined as:
unsigned long long ADC_GetSquareSum(void);
"I'm afraid to use this compiler any further"
You do realise that Keil discontinued this product some time ago...?
Does CARM actually support 'long long' ?
