Hi there, Iam unable to view the CAN SFR , CAN1GSR (w.r.t. LPC2368 controller) which is declared(i.e.#defined) in the header file LPC23xx.h . If i try to view the same by adding it to the watch window , i get the following error. *** Restricted Version with 16384 Byte Code Size Limit *** Currently used: 3604 Bytes (21%)
WS 1,CAN1GSR _____^ *** error 34: undefined identifier
Kindly give me your suggestions to view the same.
