ULINK2 Debug Problem
Hello together,
We use ULINK for a long time on our Hardware. Now
We ve got the new ULINK2 and it doesn t work.
Our Hardware is based on a XC164CS-32F40. The JTAG interface is conform to the standard.
Programming the device works, but when I start the debugger it doesn t stop at main as it should (Option run to main is set!).
Sometimes it starts on 0xE000F2, even if there is no bootstrap mode running! Also after Reset it doesn t start at Standard-Start (0xC00000). After power on/off the target it sometimes run in the 0xC00000 range, but it does not stop at breakpoints. On single steps the debugger doesn t stop after the step.
We have two ULINK2 and both shows the same effects.
Our old ULINK works well.
Our IDE and Compiler Version are the latest one (V6.09)
Thanx for help.
Michael
