Dear all,
I have some problems with setjmp/ longjmp. I used the sample code (attached at the end). When I run my program the program steps into the trigger()-function and calls the longjump function. After this call I expect that the program steps back to the statement: if (setjmp (env) != 0) { but it does nothing and the program hangs in the longjump function. Do I have a wrong understanding of setjmp and longjmp?
Thanks for you help,
Christian
#include "setjmp.h" jmp_buf env; /* jump environment (must be global) */ int error_flag; void trigger (void) { /* processing code here */ if (error_flag != 0) { longjmp (env, 1); /* return 1 to setjmp */ } } void recover (void) { /* recovery code here */ } //----------------------------------------------------------------------------- // Main Program // int main(void) { if (setjmp (env) != 0) { /* setjmp returns a 0 */ printf ("LONGJMP called\n"); recover (); } else { printf ("SETJMP called\n"); error_flag = 1; /* force an error */ trigger (); } return 1; }
