Internal Flash start
Hi there!
Can anyone show me config file (start167.a66) and "Options for target" dialog of Keil for starting controller (st269) from internal flash.
I need this configuration:
0x0 - 0x40000 - internal flash
0x40000 - 0x80000 - external RAM
0x88000 - 0x089000 - mapping UART registers
0xFFF000 - 0x100000 - mapping ADC registers
RAM - Samsung K6X1008C2D
ROM - AM29F040B
My start167.a66 file:
_MCTC0 EQU 0
_RWDC0 EQU 1
_MTTC0 EQU 1
$SET (BTYP_ENABLE = 0)
_BTYP0 EQU 2
_ALECTL0 EQU 0
_BUSACT0 EQU 1 ; Was 0
_RDYEN0 EQU 0
_RDY_AS0 EQU 0
_CSREN0 EQU 0
_CSWEN0 EQU 0
_XPERSHARE EQU 0
_VISIBLE EQU 0
_XPEN EQU 1
_BDRSTEN EQU 0
$SET (OWDDIS_ENABLE = 0)
_OWDDIS EQU 0
_PWDCFG EQU 0
_CSCFG EQU 0
$SET (WRCFG_ENABLE = 1)
_WRCFG EQU 1
_CLKEN EQU 1
_BYTDIS EQU 0
$SET (ROMEN_ENABLE = 1)
_ROMEN EQU 1
$IF TINY
_SGTDIS EQU 1
$ELSE
_SGTDIS EQU 0
$ENDIF
_ROMS1 EQU 0 ; _ROMS1 = 0 Internal ROM mapped to segment 0
$SET (STK_SIZE = 0)
SSTSZ EQU 200H
USTSZ EQU 200H
$SET (WATCHDOG = 0)
$SET (CLR_MEMORY = 1)
$SET (INIT_VARS = 1)
$SET (DPPUSE = 1)
$SET (DPP3USE = 1)
$SET (INIT_XPERCON = 0)
V_XPERCON EQU 0000$0000$0000$0000B ; XPERCON values
$SET (ADVANCED_SYSCON = 0)
PDCON EQU 0
RTS EQU 0 ; 0 = Main oscillator
SCS EQU 0 ; 0 = Main oscillator
CLKCON EQU 0 ; 0 = Running on configured basic frequency
CLKREL EQU 0 ; possible values are 0 .. 31
ADCDIS EQU 0 ; 1 = disable Analog/Digital Converter (SYSCON3.0)
ASC0DIS EQU 0 ; 1 = disable UART ASC0 (SYSCON3.1)
SSCDIS EQU 0 ; 1 = disable Synchronus Serial Cnl SSC (SYSCON3.2)
GPTDIS EQU 0 ; 1 = disable Timer Block GPT (SYSCON3.3) ; reserved (SYSCON3.4)
FMDIS EQU 0 ; 1 = disable on-chip Flash Memory Module (SYSCON3.5)
CC1DIS EQU 0 ; 1 = disable CAPCOM Unit 1 (SYSCON3.6)
CC2DIS EQU 0 ; 1 = disable CAPCOM Unit 2 (SYSCON3.7)
CC6DIS EQU 0 ; 1 = disable CAPCOM Unit 6 (SYSCON3.8)
PWMDIS EQU 0 ; 1 = disable Pulse Width Modulation Unit (SYSCON3.9)
ASC1DIS EQU 0 ; 1 = disable UART ASC1 (SYSCON3.10)
I2CDIS EQU 0 ; 1 = disable I2C Bus Module (SYSCON3.11)
; ; reserved (SYSCON3.12)
CAN1DIS EQU 0 ; 1 = disable on-chip CAN Module 1 (SYSCON3.13)
CAN2DIS EQU 0 ; 1 = disable on-chip CAN Module 2 (SYSCON3.14)
PCDDIS EQU 0 ; 1 = disable Peripheral Clock Driver (SYSCON3.15)
$SET (INIT_RSTCON = 0)
R_RSTLEN EQU 0 ; 0 = 1024 TCL: standard duration
R_SUE EQU 0 ; 0 = Configuration cannot be changed (default)
R_CSSEL EQU 0 ; 0 = 3 CS lines (CS2# .. CS0#) (default)
R_SALSEL EQU 0 ; 0 = 4-bit segment address: A19 .. A16 (default)
R_CLKCFG EQU 0 ; 0 = CPU CLOCK = XTAL * 2.5
$SET (BUSCON1 = 1)
%DEFINE (ADDRESS1) (40000H)
%DEFINE (RANGE1) (256K)
_MCTC1 EQU 0
(MCTC1 field = 0EH).
_RWDC1 EQU 1
_MTTC1 EQU 1
_BTYP1 EQU 2
_ALECTL1 EQU 0
_BUSACT1 EQU 1 ; = 0 external (ADDRSEL1) bus disabled
_RDYEN1 EQU 0
_RDY_AS1 EQU 0
_CSREN1 EQU 0
_CSWEN1 EQU 0
$SET (BUSCON2 = 1)
%DEFINE (ADDRESS2) (88000H)
%DEFINE (RANGE2) (4K)
_MCTC2 EQU 1 ; Memory wait states is 1 (MCTC2 field = 0EH).
_RWDC2 EQU 0 ; 0 = Delay Time 0.5 States
_MTTC2 EQU 0 ; 0 = Delay Time 1 States
_BTYP2 EQU 2 ; 0 = 8 Bit Non Multiplexed
_ALECTL2 EQU 1 ; see data sheet for description
_BUSACT2 EQU 1 ; = 0 external (ADDRSEL2) bus disabled
_RDYEN2 EQU 0 ; 0 = READY# function disabled
_RDY_AS2 EQU 0 ; 0 = synchronous READY# input
_CSREN2 EQU 0 ; 0 = CS2# is independent of read command (RD#)
_CSWEN2 EQU 0 ; 0 = CS2# is independent of write command (WR#)
$SET (BUSCON3 = 0)
%DEFINE (ADDRESS3) (300000H) ; Set CS3# Start Address (default 300000H)
%DEFINE (RANGE3) (1024K) ; Set CS3# Range (default 1024K = 1MB)
_MCTC3 EQU 1 ; Memory wait states is 1 (MCTC3 field = 0EH).
_RWDC3 EQU 0 ; 0 = Delay Time 0.5 States
_MTTC3 EQU 1 ; 0 = Delay Time 1 States
_BTYP3 EQU 2 ; 0 = 8 Bit Non Multiplexed
_ALECTL3 EQU 0 ; see data sheet for description
_BUSACT3 EQU 1 ; = 0 external (ADDRSEL3) bus disabled
_RDYEN3 EQU 0 ; 0 = READY# function disabled
_RDY_AS3 EQU 0 ; 0 = synchronous READY# input
_CSREN3 EQU 0 ; 0 = CS3# is independent of read command (RD#)
_CSWEN3 EQU 0 ; 0 = CS3# is independent of write command (WR#)
$SET (BUSCON4 = 1)
%DEFINE (ADDRESS4) (0FFF000H) ; Set CS4# Start Address (default 400000H)
%DEFINE (RANGE4) (4K) ; Set CS4# Range (default 1024K = 1MB)
_MCTC4 EQU 7 ; Memory wait states is 1 (MCTC4 field = 0EH).
_RWDC4 EQU 1 ; 0 = Delay Time 0.5 States
_MTTC4 EQU 1 ; 0 = Delay Time 1 States
_BTYP4 EQU 2 ; 0 = 8 Bit Non Multiplexed
_ALECTL4 EQU 0 ; see data sheet for description
_BUSACT4 EQU 1 ; = 0 external (ADDRSEL4) bus disabled
_RDYEN4 EQU 0 ; 0 = READY# function disabled
_RDY_AS4 EQU 0 ; 0 = synchronous READY# input
_CSREN4 EQU 0 ; 0 = CS4# is independent of read command (RD#)
_CSWEN4 EQU 0 ; 0 = CS4# is independent of write command (WR#)
Thanks for all!
