MCBSTR9 ethernet maximum throughput at 96MHz
I am using MCBSTR9 evaluation boards for testing the ethernet throughput (sending 1316 bytes length UDP packets).
I have implemented my code using the Keil HTTP demo with RTX_Kernel and running the board at 96MHz.
The maximum speed I got is (aprox) 40Mbit/s but I have two questions:
1. Is it possible to set FMICLK = RCLK = 96Mhz (now is RCLK/2) ?? (PLL config (2,192,25), Or there is any kind of speed limitation??
2. Is there any other TCP/IP stack optimized for this board to get a higher throughput??
thanks,
Firin
