the program doesn't do what it should... first of all when i debug it doesn't enter main function
when i compile linker gives 4 warnings
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?C_INITSEG *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?_MAIN?RAMSES *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?_INIT_MEMPOOL?INIT_MEM *** WARNING L10: CANNOT DETERMINE ROOT SEGMENT Program Size: data=28.6 xdata=8366 code=30287
i have a main function but no init_mempool or init_mem file
sir mister chirac
warnings l16 not be good but not problem in bad code
is functions notting be call be called called by you!
warning l10 is bad and is means you not say where is start
must fix is code start in code memooory start for options you be thinking
