The crystal is a 12 Mhz //#include "F100GlobalDataTypeDefs.h" //#include "F100GlobalDef.h" //#include "F100GlobalVars.h" //#include "F100Functions.h" //#include "F100HW.h"
void msecWait(uint milliSeconds) { /* Since the counter counts up it is necessarey to subtract the nuber of counts/millsecnd from the maximum count for the sixteen bit unsigned intiger (65535 - 922 = 64613 = 0xFC65) seperated into bytes (uchar) hiByte = 0xFC and lowByte = 0x65 */ // uchar highByte = 0xfc, lowByte = 0x65; //922 counts/(milisecond up count) // count is from 64613 (0xfc65)
// bit bitET0, bitTR0;
/************ Based on 12 MHz crystal**** Input in miliseconds ***************
bitTR0 = TR0; // Save TR0 // TR0 = 0; // Stop T0 // bitET0 = ET0; // Save ET0 // ET0 = 0; // Disable T0 // while (milliSeconds > NOMILLISECONDS) { TH0 = highByte; TL0 = lowByte; TR0 = 1; //start timer 0 // while (!TF0) {;} TR0 = 0 ; // stop timer 0 // TF0 = 0 ; milliSeconds--; } ET0 = bitET0; // Restore ET0 // TR0 = bitTR0; // Restore TR0 // */ }
Did you took care about the mode in which the timer0 is running. Its possible that the timer is running as 8 bit timer and not 16 bit as intended.
Suvidh
The set up is:
//--------- Serial Communication Set-up ----------- SCON = 0x70; // Set serial communication in mode 01 // (8-bit) and reciever enabled (RI = 1). PCON = 0x00; // Set SMOD0 = 0. T2CON &= 0xF0; // Set timer 2 as baud rate generator. RCAP2H = 0xFF; // Set 9600 baud high. RCAP2L = 0xD9; // Set 9600 baud high. SADEN = 0xFF; // Enable slave address // for automatic address recognition. SADDR = F100ADDRESS; // Address of data byte (0xF3). RCLK = 1; // Receiving baud rate clock. TCLK = 1; // Transmission baud rate clock. SM2 = 1; // Enable automatic address recognition. IE = 0x1E; // Enable timer 1, 0, External 1, and serial interrupts. EA = 1; // Enable global interrupt flag. TR1 = 1; // Start timer 1. TR2 = 1; // Start timer 2. ET1 = 1; // Enable Timer 1 interrupt. EX1 = 1; // Enable External interrupt 1. IP = 0x10;// Set Serial Interrupt as highest priority.
Checking on th 8-16 bit
SCON = 0x70; // Set serial communication in mode 01 // (8-bit) and reciever enabled (RI = 1). PCON = 0x00; // Set SMOD0 = 0. T2CON &= 0xF0; // Set timer 2 as baud rate generator. RCAP2H = 0xFF; // Set 9600 baud high. RCAP2L = 0xD9; // Set 9600 baud high. SADEN = 0xFF; // Enable slave address // for automatic address recognition. SADDR = F100ADDRESS; // Address of data byte (0xF3). RCLK = 1; // Receiving baud rate clock. TCLK = 1; // Transmission baud rate clock. SM2 = 1; // Enable automatic address recognition. IE = 0x1E; // Enable timer 1, 0, External 1, and serial interrupts. EA = 1; // Enable global interrupt flag. TR1 = 1; // Start timer 1. TR2 = 1; // Start timer 2. ET1 = 1; // Enable Timer 1 interrupt. EX1 = 1; // Enable External interrupt 1. IP = 0x10; // Set Serial Interrupt as highest priority.
Isn't that better?
