Hi!
I want to make a program which receives code from the PC and stores the code in the flash-memory. So, i have to copy the UpdaterCode from the flash in the RAM and then start updating the flash. But the linker crashes. There is no error message only a warning: UNRESOLVED EXTERNAL(s). There is a message box from Windows: An Error occured, do you want to send a problem report?
Here is a piece of TinyUpdater.h:
#pragma HLARGE #pragma RENAMECLASS (FCODE=FLASH_CODE) #define SROM_PS(n) \ extern unsigned char huge _PR_##n##_s_; /* section source start */ \ extern unsigned char huge _PR_##n##_l_; /* section len */ \ extern unsigned char huge _PR_##n##_t_; /* target address */ #define SROM_PS_TRG(n) ((void *) &_PR_##n##_t_) #define SROM_PS_SRC(n) ((void *) &_PR_##n##_s_) #define SROM_PS_LEN(n) ((unsigned int) &_PR_##n##_l_)
My main module:
SROM_PS(PFLASH) ... PSW_IEN = 0; // Global Interrupt disable _nop_(); _nop_(); hmemcpy (SROM_PS_TRG(PFLASH), SROM_PS_SRC(PFLASH), SROM_PS_LEN(PFLASH)); // Kopiert TinyUpdater in PSRAM TinyUpdater(); // Tiny Updater, Rücksprung in diese
Commands for linker, in the L166 Locate menu, User Sections:
?PR?PFLASH%FCODE (0xE00000)[]
Versions:
IDE-Version: µVision3 V3.05e Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2004 Tool Version Numbers: Toolchain Path: C:\Keil\C166\BIN\ EC++ Compiler: EC166.Exe V1.06 C Compiler: C166.Exe V5.05 Assembler: A166.Exe V5.04 Linker/Locator: L166.Exe V5.07 Librarian: LIB166.Exe V4.25 Hex Converter: OH166.Exe V4.7 CPU DLL: S166.DLL V2.44a Dialog DLL: D167.DLL V2.43a Target DLL: BIN\UL2OCDS.DLL V1.00 Dialog DLL: T167.DLL V2.43
Thanks Stefan Zimmermann
Yes, im out out of support. Has this version of the linker a problem with the program?
I tried your link, an it works fine as example code. If i try to adapt it to my program, i get this problem.
You are using an old version, are you out of support?
This may help: http://www.keil.com/download/docs/275.asp
