need help getting started
I have been studying the tutorial for the 8051 at http://www.8052.com. For starters, I am writing a simple assembler code for an AT89S8253 microcontroller which will read inputs on Port1 and output it to Port3. I am using the demo C51 software from KEIL and am also using the AT89ISP cable to download the hex file onto my device. I am running the XTAL1 input at 4 MHz and have the device setup on a Teradyne J750 tester. I wrote a simple program, but I am getting timer or clock-like outputs from Port2. I am not sure how to proceed (whether I need an include file, the correct syntax, etc.). Also, can you recommend good references (books, websites)? I am new at this, so I would really appreciate the help.
