To whom may help,
I'm trying to debug a small program in keil uVision 3 together with Proteus VSM 6.9 SP4 considering a LPC2106 microcontroller, but i have the following error message in proteus and keil:
Proteus: SIMULATION LOG ============== Design: D:\teste\design_proteus.DSN Doc. no.: <NONE> Revision: <NONE> Author: <NONE> Created: 26/03/07 Modified: 26/03/07
Compiling source files... Build completed OK. Compiling netlist... Linking netlist... WARNING [LINKER] : Unresolved module pin 'U1_XTAL1'. WARNING [LINKER] : Unresolved module pin 'U1_XTAL2'. Partition analysis...
Simulating partition 1 [C41B27E5]... PROSPICE Release 6.9 SP4 (C) Labcenter Electronics 1993-2006. SPICE Kernel Version 3f5. (C) Berkeley University ERL.
Reading netlist... Reading SPICE models... Building circuit... Instantiating SPICE models... ERROR: [U1_ARMCORE] PROGRAM property not specified. [U1_SYSCON] Memory configuration: 128KB ROM, 64KB RAM [DSIM] BOOT Error. Real Time Simulation failed to start Totaliters=0, Totalsteps=0, Goodsteps=0, Badsteps=0
Real Time Simulation FAILED.
And below, the keil log (Keil warns that the correct design was not loaded in Proteus):
API[0]: vdm_open API[0]: vdm_init COMMAND[0]: code=1, space=0, addr=00000000, data=128 RESULT[0]: 5 API[0]: vdm_close
***VDMAPI Terminated
As far as I know, keil as well as proteus were properly configured. In fact, they communicate with each other but the above error occurs. In the case of proteus, if i set the hex file inside LPC2106, it executes normally. Anyone can help me? !
Regards
