Limitation of the compiler or what???
Hey folks,
I have a problem really interesting here. My program is really simple, I have just to read some information from analog inputs and send them throught CAN bus. I am using the microcontroller 167.
The source of the main function is showed on next:
void main(void)
  ubyte a, b, c, d, e, f, g, h;
  uword Gas = 0;
  uword Brake = 0;
  MAIN_vInit();
  while (1) {      /* loop forever*/
    Gas = ADC_ReadChannel(0);
    Gas = Gas & 0x3ff;
    a = LOWER_BYTE(Gas);
    b = UPPER_BYTE(Gas);
    Brake = ADC_ReadChannel(1);
    Brake = Brake & 0x3ff;
    c = LOWER_BYTE(Brake);
    d = UPPER_BYTE(Brake);
    while ( !CAN1_ubRequestMsgObj(1) );
    CAN1_vLoadData(1,0,a);
    CAN1_vLoadData(1,1,b);
    CAN1_vLoadData(1,2,c);
    CAN1_vLoadData(1,3,d);
    CAN1_vTransmit(1);
} //  End of function main
So, when I test the program in the target hardware, the information that I read in CAN network (I have a monitor program in my PC connected in the CAN net) is supposed to show what I am reading from the analog inputs.
Well, when I read only one analog input and send by CAN, the program work well. But if I am reading two of analong inputs (as in the source code showed) and send these information by CAN, the ouptut comes wrong, always comes like 0xFF. I checked if there is a problem in the CAN drivers, but there is not. The problem is a simple basic operation of bits manipulation. How is it possible?
As I commented, if I commented the lines concerned with Brake analog input, for example, the program works.
//    Brake = ADC_ReadChannel(1);
//    Brake = Brake & 0x3ff;
//    c = LOWER_BYTE(Brake);
//    d = UPPER_BYTE(Brake);
//    CAN1_vLoadData(1,2,c);
//    CAN1_vLoadData(1,3,d);
Could someone explain me why is that? THere is some limitation on the compiler? Looks like a problem in the ocmpiler!
I am using DAvE to generate the drivers for CAN and ADC.
I am looking forward to hearing from someone!
  • I am not sure what version of Dave you are using to generate the function "CAN1_vLoadData". Have you changed it?
    In the version I have the function is:
    void CAN1_vLoadData(ubyte ubObjNr, ubyte *pubData);
    You need to provide more details as to what the code looks like in the functions or macros before I would say it is a compiler issue.
