I am using SPRINTF() function and it increase the code by 2.3K. Is there any method to reduce the code size.
Thanks,
Mashood
sprintf() is a very comprehensive and powerful function and so it comes with a big memory footprint.
What you could do is identify what part of the sprintf() functionality you actually need and "roll your own" string formatting function.
Thanks you all, I got your point. Now my code size is slighly above 10K and I was using AT89C52 before and now I couldn't. So which controller from the same 51 family should i use. I have 89C55WD in hand with 20k program memory. Can it be used with the same code without any other settings in program or during program burn.
"Can it be used with the same code without any other settings"
You would need to confirm that by comparing the two datasheets.
