I am presently working on a port from the CARM Compiler to the Realview. The startup.s file provided in the Keil folder for the realview does not work entirely on my project for the LPC2148. When I run it, it seems to always hit the Data Abort Handler.
Below is the previous CARM compiler startup file stack configuration
/* // <h> Stack Configuration (Stack Sizes in Bytes) // <o0> Undefined Mode <0x0-0xFFFFFFFF:4> // <o1> Supervisor Mode <0x0-0xFFFFFFFF:4> // <o2> Abort Mode <0x0-0xFFFFFFFF:4> // <o3> Fast Interrupt Mode <0x0-0xFFFFFFFF:4> // <o4> Interrupt Mode <0x0-0xFFFFFFFF:4> // <o5> User/System Mode <0x0-0xFFFFFFFF:4> // </h> */ UND_Stack_Size EQU 0x00000004 SVC_Stack_Size EQU 0x00000004 ABT_Stack_Size EQU 0x00000004 FIQ_Stack_Size EQU 0x00000004 IRQ_Stack_Size EQU 0x00000080 USR_Stack_Size EQU 0x00000400
AREA STACK, DATA, READWRITE, ALIGN=2 DS (USR_Stack_Size+3)&~3 ; Stack for User/System Mode DS (SVC_Stack_Size+3)&~3 ; Stack for Supervisor Mode DS (IRQ_Stack_Size+3)&~3 ; Stack for Interrupt Mode DS (FIQ_Stack_Size+3)&~3 ; Stack for Fast Interrupt Mode DS (ABT_Stack_Size+3)&~3 ; Stack for Abort Mode DS (UND_Stack_Size+3)&~3 ; Stack for Undefined Mode Top_Stack:
Tbe new configuration is
;// <h> Stack Configuration (Stack Sizes in Bytes) ;// <o0> Undefined Mode <0x0-0xFFFFFFFF:8> ;// <o1> Supervisor Mode <0x0-0xFFFFFFFF:8> ;// <o2> Abort Mode <0x0-0xFFFFFFFF:8> ;// <o3> Fast Interrupt Mode <0x0-0xFFFFFFFF:8> ;// <o4> Interrupt Mode <0x0-0xFFFFFFFF:8> ;// <o5> User/System Mode <0x0-0xFFFFFFFF:8> ;// </h>
UND_Stack_Size EQU 0x00000000 SVC_Stack_Size EQU 0x00000008 ABT_Stack_Size EQU 0x00000000 FIQ_Stack_Size EQU 0x00000000 IRQ_Stack_Size EQU 0x00000080 USR_Stack_Size EQU 0x00000400
Stack_Size EQU (UND_Stack_Size + SVC_Stack_Size + ABT_Stack_Size + \ FIQ_Stack_Size + IRQ_Stack_Size + USR_Stack_Size)
AREA STACK, NOINIT, READWRITE, ALIGN=3 Stack_Mem SPACE Stack_Size Stack_Top EQU Stack_Mem + Stack_Size
;// <h> Heap Configuration ;// <o> Heap Size (in Bytes) <0x0-0xFFFFFFFF> ;// </h>
Heap_Size EQU 0x00000FA0 ; 4k heap size AREA HEAP, NOINIT, READWRITE, ALIGN=3 Heap_Mem SPACE Heap_Size
; User Initial Stack & Heap AREA |.text|, CODE, READONLY
IMPORT __use_two_region_memory EXPORT __user_initial_stackheap __user_initial_stackheap
LDR R0, = Heap_Mem LDR R1, =(Stack_Mem + USR_Stack_Size) LDR R2, = (Heap_Mem + Heap_Size) LDR R3, = Stack_Mem BX LR
Any suggestions on what may need to be changed?
You may analyse the reason for the DATA ABORT as explained in: http://www.keil.com/support/docs/3080.htm
I suggest that you run first one of our demo examples in the folder ..\RV30\Boards\Keil\MCB2130 or ..\RV30\Boards\Keil\MCB2130.
I've changed from CARM to Realview too. I'm facing the same problem with LPC2129. Following the Data abort analisys the problem is in the __SWI_2 subroutine in the ar_lib.o (I don't have the source code of ARTX).
