Hi I have tried to use PLL. i think i have wrongly configured the PLL. now im unable to download flash with ULINK2. Following message is there every time i try to download flash from my u Vision3 IDE version 3.04. "Error:lash download failed-target DLL has been cancelled" help me to get out from this problem. MCU is LPC2366. n development board is MCB2300.
Please recover the device using FlashMagic. In the on-line verison of the user's guide, the configuration for FlashMagic is documented:
www.keil.com/.../mcb2300_fp_flash_utility.htm
FlashMagic has an erase command that clears the content of the on-chip Flash ROM.
Sir, I have tried to erase the chip with flash magic according to setting given in the link provided by you. But there is communication failure between MCB 2300 and PC. i am using a cross cable for the connection of PC and MCB2300.
Communication is also failed on another working MCB2300 board. what should i do now.
