hello every one,
I am trying to use bitfield in my project. i want to assign the port address to the byte which i have created using bitfield.
/* following is the code i have tried */ typedef union { byte Byte; struct { byte Pb0 :1; byte Pb1 :1; byte Pb2 :1; byte Pb3 :1; } Bits; struct { byte Pbyte :8; } MergedBits; } Ppins; extern volatile Ppins _PTAD @0x00000000; #define FByte _PTAD.Byte #define Bit1 _PTAD.Bits.Pb0 #define Bit2 _PTAD.Bits.Pb1 #define Bit3 _PTAD.Bits.Pb2 #define Bit4 _PTAD.Bits.Pb3
can i give the address in this way or is there any other way to do this. Please help me out.
