I have an array of structs, which I would like to initialize at startup, but to my surprise this gives me a compiler syntax error:
I do as follows:
typedef volatile struct Timer { BYTE byStatus; WORD wValue; void (code *pfHandler) (void); } T_TIMER; volatile T_TIMER g_aSWTimers[TIMER_NO_OF_TIMERS] = { { .byStatus = 0; .wValue = 0; .pfHandler = OnIgnoreSpeedTimer; }, { .byStatus = 0; .wValue = 0; .pfHandler = OnIgnoreFM1Timer; } };
And it gives me a warning saying
"TIMERINTS.C(108): error C141: syntax error near '.'"
Could anyone please point me in the right direction?
Thanking you all in advance.
Best regards Henrik
volatile T_TIMER g_aSWTimers[TIMER_NO_OF_TIMERS] = { {0, 0, OnIgnoreSpeedTimer}, {0, 0, OnIgnoreFM1Timer} };
"to my surprise this gives me a compiler syntax error"
This should come as no surprise at all! The compiler is quite correct - that is not valid 'C' syntax by a long way!
"Could anyone please point me in the right direction?"
Any decent 'C' textbook, the section on defining structs with initialisers!
Thank you both for your fast replies.
Actually you are right, it should have comes as no surprise at all. In the mean time between posting and writing this post, I pulled out my good ol' Kernighan&Richie and found that I was wrong.
However, this method works with the GNU C compiler, so that is what confused me.
Thank you once again.
"However, this method works with the GNU C compiler, ..."
GNU C implements some of C99; "designated initializers" in this case.
