I'm pretty sure I know the answer to my question, but I like verification.
Say I have an array in xdata:
unsigned char xdata foo[32];
I have a function which accepts a pointer and does stuff with it:
void doSomething(unsigned char *ptr, ...) {}
Now, if I pass a pointer to foo to my function:
doSomething(foo, ...);
will accesses to/from ptr in the function use MOVX or will the whole thing blow up?
Or do I need to be explicit about how I write the doSomething function header:
void doSomething(unsigned char xdata *ptr, ...)
I suppose I could make foo[] a global, but I'm trying to keep this generic.
-a
The rules of how the compiler copes with conversions between generic and memory-specific pointers are described in the Manual
Either format will work. Pass an xdata pointer to a generic pointer, and the compiler adds the tag byte. Pass a generic to an xdata, and the tag byte gets removed. There are differences between register usage and efficiency which are explained in the manual.
