Hello EveryBody, I am working on LCD (16x2) and i have built some of my ideas about LCD programming but i am using Assembly language for my LCD, well as all things was going sweet so as every programmer is having something wrong ... (in starting) my problem specification is that i am using that LCD in 8-bit mode and i have connected my AT89C2051 (with some pull-ups) P1 DB P3.7 RS P3.5 RW P3.4 E and i have interfaced my LCD with my MCu but my problem is that i am getting the LCD not working ... (i dont know why) .... i have interfaced my LCD but there only little bit of contrast....i mean to say that there nothing visible... even i move my 10K-ohm-POT to the ground.....
and i have done some programming, so could any one please help me .... (i am really stucked) any help will be appritiatable.....
<code> ORG 0000H LJMP MAIN ORG 0030H RS EQU P3.7 RW EQU P3.5 EN EQU P3.4 MAIN: LCALL DELAY CLR EN MOV DPTR,#MYCOM LCALL LCD_INI MOV DPTR,#MYDATA LCALL LOOP MOV A,#0C9h LCALL COM LCALL DELAY MOV DPTR,#MYDAT2 LCALL LOOP AGAIN: SJMP AGAIN ;======================================== COM: MOV P1,A CLR RS CLR RW SETB EN LCALL DELAY CLR EN RET ;======================================== DATAW: MOV P1,A SETB RS CLR RW SETB EN LCALL DELAY CLR EN RET ;======================================== DELAY: MOV R6,#100 HERE2: MOV R7,#250 HERE: DJNZ R7,HERE DJNZ R6,HERE2 RET ;======================================== LCD_INI: CLR A MOVC A,@A+DPTR LCALL COM LCALL DELAY JZ GO_B1 INC DPTR SJMP LCD_INI GO_B1: RET ;======================================== LOOP: CLR A MOVC A,@A+DPTR LCALL DATAW LCALL DELAY INC DPTR JZ GO_B2 SJMP LOOP GO_B2: RET ;======================================== MYCOM: DB 38H,0EH,06,01,84H,0 MYDATA: DB "DAREDEVIL",0 MYDAT2: DB "GUNS AND ROSES",0 ;======================================== END </code>
Asif Ali "DareDevil"
There are 3 things that you need to do: 1) Get the tech docs for the LCD and read it. The document will have a table showing all the command words and probably a flow diagram on how to initialize and read/write data to the LCD.
2) There are a lot of code samples on the web. Try searching.
3) Why assembly? Try learning 'C'.
Hello sir I as you have said that Why Assembly ? use C. so sir the answer is that i was C programmer but for evantually i have learnt the Assembly just for my LCD interfacing and i have done very much hard working in learning Assembly :-( well i will create the program in C also but as you have pointed out that pin3 to ground ... well i have tried that but there is problem that only the Second coulmn of LCD is showing me Black boxes ... and that boxes are not very much black .... (Why?)
And thank you for your Reply well and hoping that you will help me little more..
i have read the DataSheet of 16x2 LCD (HD44780A) but nothing good is happend .... :-(
i was C programmer 1) that C is 'self documenying' is a myth that has been debunked often, did you believe that one? 2) whatever C is or is not, assembly definitely is not in any way 'self documenying'
hoping that you will help me little more gladly will help with commented code.
The amazing thing is that if you commented your code and, as suggested above, compared it to the flowchart in the LCD datasheet I would bet you would find the problem yourself.
erik malund wrote: "The amazing thing is that if you commented your code ... I would bet you would find the problem yourself"
Absolutely. Code documentation is not meant just for 'other people read'. A well commented code will capture the programmer's intentions and clarify the effects of the related logic.
The best definition for a bug I've ever seen is:
A bug is a mismatch between the documentation and the actual behavior of a program.
You can write spaghettiware in pretty much any language. It doesn't really matter whether you program in C, Python or Assembly, as long as you write clear comments and structure your code cleanly. But PLEASE, never write comments like "load 0x41 into the accumulator", or "go to LOOP".
I wrote above: "None of the instructions you are using affect the Z flag, ..."
Which is ABSOLUTE NONSENSE! Please forgive-me for that. OF COURSE, the 8051 core has no Z flag. Testing for zero in A should work as written. (thank you all for not flaming immediately)
The fact that I routinely write 8051 assembly functions does not make my gross mistake better. I can only blame it to cross-cpu contamination or brain damage :-0
Anyway, I am following this subject in the other forum you have started, and you seem to have progressed to the point of locating your mistake in the initialization code. The Hitachi documentation specifies that you send the init sequence to the display 4 times, with a delay of 10ms between sequences. Check your timings.
Well sir i have checked my initialization according to HD44780 in my simulator i have found that its 0.012S so i think that its very enough for delay purpose Right ?
ORG 0000H LJMP MAIN ORG 0030H ;initialization MAIN: MOV A,#038H ;first time LCALL COM MOV A,#038H ;second time LCALL COM MOV A,#038H ;third time LCALL COM MOV A,#038H ;fourth time LCALL COM MOV A,#00EH LCALL COM MOV A,#001H LCALL COM MOV A,#006H LCALL COM MOV A,#084H LCALL COM ;initialization End MOV A,#'A' ;data to write on LCD LCALL DATAW MOV A,#'L' LCALL DATAW MOV A,#'I' ;data end LCALL DATAW AGAIN: SJMP AGAIN ;endless loop COM: MOV P1,A ;command write sequence CLR P3.7 CLR P3.5 SETB P3.4 CLR P3.4 ;LCALL DELAY RET DATAW: MOV P1,A ;data write sequence SETB P3.7 CLR P3.5 SETB P3.4 CLR P3.4 ;LCALL DELAY RET DELAY: MOV R6,#50 ;simple delay routine HERE2: MOV R7,#255 ;for 0.0124S or 124MS HERE: DJNZ R7,HERE DJNZ R6,HERE2 RET END
Hint for initialization - first parameter for DspPutc is the RS signal level:
DspPutc(0, 0x38); /* FUNCTION_SET - 8-bit interface; 2-line display; 5x7 dots */ DspPutc(0, 0x0C); /* DISPLAY_MODE - Display ON; Cursor OFF; Blinking OFF */ DspPutc(0, 0x01); /* DSP_CLR_MODE - Clear display */ LCD_Wait(1640); /* wait 1.6 msecs */ DspPutc(0, 0x06); /* ENTRY_MODE - Cursor Increments; Display not shifted */
This came fram the display data sheet flow chart and operational table. Check the waveform timing for approxiate delays.
Why 'C'. Its portable. To port this code, only DspPutc needs to be modified for the I/O pins.
The above code is only small portion from an Ioctl function that I wrote.
in this case it is not 1) how does C 'port' to some processor with no p1, no quasi-bidirectionals. 2) you can not make a 'portable' delay routine in C 3) C is quite 'portable' in many respoects, but there is no way in hades you can make any I/O function 'portable' between processors whatever language you use.
There's always code that needs to be changed between processors. The I/O layer. In the Display case, the I/O is in the DspPutc function. In this function, the code can be changed to access the LCD using an 8 or 4 bit bus or by serial means if the LCD supports that mode.
you said: Why 'C'. Its portable. now you say ... needs to be changed ... be changed to ... or by .. if ... supports
some portability.
this is NOT an argument aginst using C (I do it extensively) but the "portability" is very limited in small embedded. In small embedded the ease of coding is the important factor, the likelyhood that a project ever will be moved to another processor family is virtually zero. So, if it works in assembler, let sleeping dogs lie.
erik malund said: "this is NOT an argument aginst using C (I do it extensively) but the "portability" is very limited in small embedded."
I agree with erik. In C, often the compiler choices, memory layout and linker scripts are so different from a processor to the next, that major redesign is inevitable.
For example, writing precise timing loops in C is often a waste of time, because you simply can't control the machine code generated from the C source. A simple change in compiler optimization level can wreck you timings.
Especially when you need to push the performance, you tend to write a C style that matches the particular processor you target. There are always specific ways to write loops, logic sequences, expressions, function prototypes that match more closely a given processor.
An embedded programmer that is conscious of these styles will write faster and smaller C code, often deviant from ANSI. When you are struggling to fit a 80KB code in a 64KB processor flash, that's a go/no_go issue.
"So, if it works in assembler, let sleeping dogs lie"
Absolutely. I have seen C code that is virtually unrecognizable. As a matter of fact, the assembly portions of the large systems we work with are generally much better documented and maintainable, because they were usually written by a careful coder.
Almost all large systems we produce have the lower lib layer written in hand-optimized assembly for the target processor core.
"writing precise timing loops in C is often a waste of time"
Rather than "often", I'd say "always" - certainly for precise timing:
"because you simply can't control the machine code generated from the C source."
Absolutely - because you can never control it, it is always a waste of time!
"A simple change in compiler optimization level can wreck you timings"
Even without changing optimisation; eg, if the compiler happens to be using a register in your delay, then you add some "unrelated" code and the compiler happens to use the register for this and therefore something else in your loop...
