Hi ! Have ULINK and MCB2100 with processor LPC2119. In an effort insert in any project function printf() , program in step of execution stops in file "STARTUP.S" on operator:
PAbt_Handler B PAbt_Handler
Compiler and linker give 0 errors, 0 warning. Such problem so appears while working with simulator. The Port UART1 is initialized in accordance with your example: "Hello.Uv2". The File "stdio.h" is connected.
Alex.
Looks like you have not added the file retarget.c.
Anyway, if you want to detect the location of the data abort take a look here:
http://www.keil.com/support/docs/3080.htm
Hi! Thank you, once again! Has Connected other file "retarget.c" from project...\Keil\ARM\RV30\Startup. All have earned! Alex.
So your problem is solved now?
