I am currently working on a project . the chip that i am using is phillips P89V51RD2FA .The chip is embedded in a board created by EMBIN TECHNOLOGIES , MUMBAI , INDIA and is called ETD 140 .
i tried using crossware embedded studio to tramnsmit data to the board . i followed the instructions given in the manual . i used the specified baud rate. the data was shown as sent but i could not execute the programme .When i sent the same programe using FLASH MAGIC , the program was executed . Could u please tell me if the software is compatible with the chip i used . if so , could you please tell me what should i do regarding the serial transfer of programme . i want to programme the chip and use it in a stand alone mode .
could you also please tell me how to use the debugger in the soft ware. I humbly request you to please help me in this .
So what is the problem?
"i tried using crossware embedded studio"
Is that a Keil product?
http://www.keil.com/forum/
flash magic dosent support debugging . so in order to debug i have to use another software . i want to know whether croosware is compatible with the chip.
"i want to know whether croosware is compatible with the chip."
So why don't you ask them?! http://www.crossware.com/
hi
thanks a lot 4 the info....
regards
abdul aziz
