I'm using uVision 3.33, supplied as part of the Luminary Micro design contest. I've noticed the following problem when trying to right-shift a 16-bit unsigned value.
The code produced is:-
176: unsigned short int16; 177: 178: void testfunc(void) 179: { 0x0000072E BD10 POP {r4,pc} 180: int16 >>= 1; 0x00000730 480A LDR r0,[pc,#40] ; @0x0000075C 0x00000732 8800 LDRH r0,[r0,#0x00] 0x00000734 4909 LDR r1,[pc,#36] ; @0x0000075C 0x00000736 8008 STRH r0,[r1,#0x00] 181: }
.. which does not do a right shift !
If I do a left shift, however, it works:-
176: unsigned short int16; 177: 178: void testfunc(void) 179: { 0x0000072E BD10 POP {r4,pc} 180: int16 <<= 1; 0x00000730 480C LDR r0,[pc,#48] ; @0x00000764 0x00000732 8800 LDRH r0,[r0,#0x00] 0x00000734 F64F71FF MOVW r1,#0xFFFF 0x00000738 EA010040 AND r0,r1,r0,LSL #1 0x0000073C 4909 LDR r1,[pc,#36] ; @0x00000764 0x0000073E 8008 STRH r0,[r1,#0x00] 181: }
.. with the LSL instruction clearly visible.
Is this a known bug in the Keil compiler ?
Thanks,
Pete Baston.
Not sure what versions of the simulator and compiler you are using. It works with uVision V3.35, SarmCM3.DLL V3.01 and RVCT3.0 [Build 947]:
136: int16 >>= 1; 0x000001FC 483D LDR r0,[pc,#244] ; @0x000002F4 0x000001FE 8801 LDRH r1,[r0,#0x00] 0x00000200 0849 LSRS r1,r1,#1 0x00000202 8001 STRH r1,[r0,#0x00] 137: } 138: 0x00000204 4770 BX lr
There have been some fixes to the Cortex-M3 simulation engine.
Thanks for your reply. I have uVision 3.33 which includes ARMCC 3.0.0.942 and SARMCM3.DLL 3.01. I'm not sure what RVCT is - can't see it listed.
I would have thought the problem would be with the compiler - how does the simulation engine come into it ?
I think there might be an updated development kit CD available - I'll try that and see if it fixes the problem.
Best Regards,
Pete.
Pete,
RVCT means 'RealView Compilation Tools' and consists of ArmCC, ArmAsm, ArmLink and the includes and libraries.
You can find out your versions and build info by using the uVision menu command 'Help - About uVision...'.
Regards, Peter
Hi Peter
Here's the version info from my uVision.
IDE-Version: µVision3 V3.33b Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2006 License Information: Peter Baston PB Engineering LIC=---- Tool Version Numbers: Toolchain Path: C:\Program Files\Keil\ARM\BIN30\ C Compiler: ARMCC.Exe V3.0.0.942 Assembler: ARMASM.Exe V3.0.0.942 Linker/Locator: ARMLINK.Exe V3.0.0.942 Librarian: ARMAR.Exe V3.0.0.942 Hex Converter: FROMELF.Exe V3.0.0.942 CPU DLL: SARMCM3.DLL V3.01 Dialog DLL: DLM.DLL V1.00a Target DLL: BIN\lmidk-agdi.dll V??? Dialog DLL: TLM.DLL V1.00
I am running the following version, which is RVCT3.0 with service pack 1:
IDE-Version: µVision3 V3.50 Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2007 Tool Version Numbers: Toolchain Path: BIN30\ C Compiler: ARM/Thumb C/C++ Compiler, RVCT3.0 [Build 951] for uVision [Full] Assembler: ARM/Thumb Macro Assembler, RVCT3.0 [Build 951] for uVision [Full] Linker/Locator: ARM Linker, RVCT3.0 [Build 951] for uVision [Full] Librarian: ARM Archiver, RVCT3.0 [Build 951] for uVision Hex Converter: ARM FromELF, RVCT3.0 [Build 951] for uVision [Full] CPU DLL: SARM.DLL V3.04 Dialog DLL: DARMAT.DLL V1.04 Target DLL: BIN\UL2ARM.DLL V1.26 Dialog DLL: TARMAT.DLL V1.03
