DPP error with variables initialized at compile time
I have a program with manystructures that are statically allocated at compile time, and there is a problem with DPPs.
The memory configuration is:
ROM 0x0 -> 0x3FFF
RAM 0x4000 -> 0x7FFF
DPP1 points to NCONST and is correctly set to 0
DPP2 points to NDATA and is correctly set to 1
I have a structure (structA) that is set in RAM, its address is 0x544A
I set a second structure (structB), which is initialized at compile time:
tpl_alarm structB = {
    /* kind of the alarm    */  ALARM_TASK_ACTIVATION,
    /* action of the alarm  */      {
                                        (tpl_task *)&structA
    /* event if necessary   */      (tpl_event_mask)0
When I look at structB, I can found that the value of the pointer is 0x544A!!!
But structA resides in the NDATA memory, and MUST use DPP2!!!
I expected the value 0x944A to use DPP2!!
(tpl_task *) is the correct type of structA.
Thanks for any help,
M.Briday
