C8051F120 timer Problem
Hi frnds,
I am using Silabs C8051F120, I wanted to have timer delay of 1-msec (One milli second), Since both timers 0 & 1 are used for som application.
I had left with Timers 2,3,4 , so i used timer 2 for calculating delay of 1 msec, which can be called specified number of times * 1 Msec., I am polling for Timer 2 overflow flag TF2.., but som how the code is not working..,
I have used Timer 2 , 16 bit timer with compare capture mode., If there is any solution to this problem , plz let me know..
code:
// Timer2_ms
// Configure Timer-2 to delay <ms> milliseconds before returning.
                void Timer2_ms (unsigned char ms)
                   unsigned char xdata i;             // millisecond counter
                   char SFRPAGE_SAVE = SFRPAGE;     // Save Current SFR page
                   SFRPAGE = 0x00;
                   SFRPAGE = TIMER01_PAGE;
                   TMR2CN = 0x00;
                   TMR2CF = 0x00;
                   RCAP2L = 0xCA;
                   RCAP2H = 0xEF;
                   TMR2L  = 0xCA;
                   TMR2H  = 0xEF;
                           for (i = 0; i < ms; i++)
                           {                                                   // count microseconds
                              TR2    =0;                   // STOP Timer0
                              TR2    =1;                   // START Timer0
                              while(TF2 == 0);             // wait for overflow
                              TR2    =0;                   // Stop Timer 0
                                  TF2    =0;                               // clear overflow indicator
                           SFRPAGE = SFRPAGE_SAVE;          // Restore SFR page
// Calling Function:
                   Timer2_ms (10);
With Regards,
Rajesh
  • "but som how the code is not working.."
    That is no help at all, is it?
    In what way, precisely, is it "not working"?
    What, precisely, does it do?
    What did you expect it to do?
    What debugging and investigation have you done to account for the difference?
    Have you tried it in the Simulator?
