I am using C8051F120 from Silabs.., I have connected PPI 8255 with my controller which is be addressed as External Memory interface(EMI) as I take control lines of PPI A0,A1 with lower ports of Microcontroller..
I am finding problem with interfacing using XBYTE to address externaly..,
Ex:
XBYTE[0x0000]=0xFF;
where the control lines of PPI A0,A1 r selected with address XBYTE[0x0000] and data is latched with 0xFF;
this operation is not performed properly..,
If there is any solution to this problem.. plz let me know...
Rajesh
The 8255 is a really old and slow peripheral, and the C8051F120 is one of the latest, whizziest 8051s - it's a bit bizarre to be using them together!
Anyhow, with the above in mind, are you sure that the timing on the C8051F120's External Memory interface is compatible with the 8255?
Is the EMI correctly enabled & configured?
"this operation is not performed properly"
That is really not very helpful at all, is it?
You need to describe precisely what does (or does not) happen!
Do you have access to an oscilloscope?
Of course it is not! Would a tire for a Ford T work with a Mustang Cobra?
Instead of posting "how do I use this antique" post "how do I make so and so"
1) you have 8 ports, WHY ON EARTH do you bring in this antique 2) If you HAVE TO use this old, outdated, antique chip, then instead of using the f120 to the full extent SLOW IT DOWN TO A CRAWL (to match a 8255 you will, probably, need to clock at not 100, but one MHz).
Throw the blasted 8255 out and post what you are trying to do and the 'how' will be forthcoming.
a general note: read the timing specifications in the datasheets before hooking components together.
