PPP connection problem
I have a problem.
PPP connection from MCB2130 evaluation board to PC or to another board can not be established (the connection has been made through the serial interface).
I have tried to establish PPP connection by calling function 'ppp_connect' from RLT-ARM.
I have used MCB2130 board which has been connected to PC via COM1 port by serial cable.
Source code
 *      R T L   P P P  C O N N E C T   E x a m p l e
 *      Name:    SimplePPP.C
#include <RTL.h>
#include <LPC213x.H>  /* LPC213x definitions */
/*--------------------------- init ------------------------------------------*/
void init () {
   IODIR1  = 0x00FF0000;                     /* P1.16..23 defined as Outputs  */
   /* Enable RxD1 and TxD1 pins. */
   PINSEL0 &= ~0x000F0000;
   PINSEL0 |=  0x00050000;
   U0LCR = 0x83;                             /* 8 bits, no Parity, 1 Stop bit*/
   U0DLL = 97;                            /* 9600 Baud Rate @ 15MHz VPB Clock  */
   U0LCR = 0x03;                             /* DLAB = 0                     */
/*--------------------------- sendchar --------------------------------------*/
int sendchar (int ch)  {
   /* Debug output to serial port. */
   if (ch == '\n')  {
      while (!(U0LSR & 0x20));
      U0THR = '\r';                          /* output CR                    */
   return (U0THR = ch);
void tick_timer (void) __task {
   os_itv_set (10);
   while (1) {
      os_itv_wait ();
      /* Timer tick every 100 ms */
      timer_tick ();
void tcp_poll_task (void) __task {
    while (1) {
      main_TcpNet();
          os_tsk_pass();
void test_task (void) __task {
   init();
   init_TcpNet ();
   //ppp_listen ("Keil", "test");
   ppp_connect (NULL, "Keil", "test");
   //slip_connect(NULL);
   os_tsk_create (tick_timer, 2);
   os_tsk_create (tcp_poll_task, 1);
   /* Init done, terminate this task. */
   os_tsk_delete_self();
int main (void) {
    os_sys_init (test_task);
/*--------------------------- init_serial -----------------------------------*/
void init_serial (void) {
   /* Initialize the serial interface */
   rbuf.in   = 0;
   rbuf.out  = 0;
   tbuf.in   = 0;
   tbuf.out  = 0;
   tx_active = __FALSE;
   /* 8-bits, no parity, 1 stop bit */
   U1LCR = 0x83;
   U1DLL = 97;                            /* 9600 Baud Rate @ 15MHz VPB Clock  */
   U1LCR = 0x03;
   /* Enable FIFO with 8-byte trigger level. */
   U1FCR = 0x87;
   /* Enable RDA and THRE interrupts. */
   U1IER = 0x03;
   VICDefVectAddr = (U32)def_interrupt;
   /* Enable UART1 interrupts. */
   VICVectAddr14  = (U32)handler_UART1;
   VICVectCntl14  = 0x27;
   VICIntEnable  |= (1 << 7);
I have used WinXP SP2 on PC, created the Incoming Connection in 'Network Connections'.
User: 'Keil'
Password 'test' .
The login information was added to WinXP and is selected as user allowed connecting.
Connection has not been established.
Also, connection was not established if function 'slip_connect' had been used.
But, connection was established successfully when I used the function 'ppp_listen' on the MCB2130 board side and PC connected to MCB2130 board.
Moreover, I need to establish connection between to MCB2130 boards via serial cable.
I use Null-Modem Male-Male cable. I run application which calls 'ppp_listen' on first board.
I run application which calls 'ppp_connect' on another board.
PPP connection is not established.
