i want use if satement, to do something for the one time, example:
main(){ char k; k=0;
while(1){
if(k==0){ printfLCD("please only one time\n"); k=1; }//end if
printfLCD("test message\n");
}//end while }//end main
but it isnt work, program enters the if statement infinite time. where is the error?, there is anyything about keilc51, which is i dont know? i use upsd3434 8051 microcontroler, sory for my nglish
Which memory model are you using (small/compact/large) ?
If you are using the large model, be aware that the compiler might try to locate the variable k in xdata memory, which might need to be enabled first on your uC (consult the uCs datasheet for details on this).
Try declaring your variable k as
unsigned char data k;
and check if the program behaves differently.
Also, please read the hints on posting source code (they appear right above the the text window when you write a posting). Following them will make your source code much more legible.
