Hi, I observed a strange behaviour (for me only) of void pointer. I wrote a code to access an integer through void pointer as below:
void *ptr; int a[2] = {1,2};
ptr = (int *)&a; ptr++; // This is giving error: Unknown Size
Why the above increment statement is giving error as i already cast the pointer to int type ?
Can anybody help me in understanding this ?
Karthik K.
No. You didn't. You cast the expression &a to an int pointer type.
Jon
Setting a void pointer to the address of an object does not change the pointer's type; it's still a void pointer.
For example, if you assigned the address of a function to a void pointer and then tried to increment the pointer, what result would you expect?
then whats the correct way?
Depends on what you are trying to do. If you are really only going to use this pointer to point to int, then make it a pointer to int. If not, explain what you are trying to do.
- mike
((int *)ptr)++;
Jon, I was trying to encourage a good style of programming in C, and you ruined it by showing an easy workaround :-) Ah well, let him learn the hard way.
Thanks to all for guiding me... So if i understood correctly, then i can say that whenever i need to access void pointer, i have to cast it to proper type.
Well, I want to improve my C knowledge. Can anyone suggest a way... ?
warning: #1441-D: nonstandard cast on lvalue
Is that ok?
get it done by somebody;
ya ok,
"I want to improve my C knowledge. Can anyone suggest a way... ?"
Do a 'C' programming course.
Get a decent 'C' textbook.
Probably best to learn the language on a PC or similar; then, once you know the language, you can learn how to apply it to microntrollers...
Thanks Neil for your suggestion. I know the basic of C, but some miscellaneous concept like void pointer, null pointer, dangling pointer,etc.. will be explored in most of the book. Generally C book gives the basic programming guide, not the in depth knowledge. Or may be but i am not aware of such book.
If any one have idea then please let me know.
Thanks Neil for your suggestion. I know the basic of C, but some miscellaneous concept like void pointer, null pointer, dangling pointer,etc.. will not be explored in most of the book. Generally C book gives the basic programming guide, not the in depth knowledge. Or may be but i am not aware of such book.
independend from the void or int pointer type, the statement "ptr = (int *)&a;" is wrong.
If a array is defined, the name of the array is the address. So the above statement gets the address of an address.
Correct is either: ptr = (int *)a; or ptr = (int *)&a[0];
ANDY, that was a nice answer, applauds, is there a reason to learn C, and THEn apply to ucontrollers,
certainly there should be other ways,
