Hi, I observed a strange behaviour (for me only) of void pointer. I wrote a code to access an integer through void pointer as below:
void *ptr; int a[2] = {1,2};
ptr = (int *)&a; ptr++; // This is giving error: Unknown Size
Why the above increment statement is giving error as i already cast the pointer to int type ?
Can anybody help me in understanding this ?
Karthik K.
Thanks Drew, I am new to C and forum posts such as this void pointer one help me learn. I searched the web for C99 and did find some examples so at least understand what it is. I will use some bits of it from now on. But at my present level of C knowlewdge will not try to do more than this.
I am struggling with multi-dimensional char arrays, pointer etc right now and am getting some odd results, but I will persevere!
"persevere!",
HOW loong can you persevere without the chip indicating ANYthing, red or green or any thing on the led?
"I am new to C ... I am struggling with multi-dimensional char arrays, pointer etc"
You might find it easier to get to grips with such issues on a PC; then, once you've mastered the language, you can move on to applying it in the specialist world of embedded microcontrollers...
Your right, but I like to see things happening! I do know assembly fairly well, and have used Forth for embedded. In fact I compared Arm Forth to Keil, but decided to go with C because I wanted to broaden my horizon and I have the opportunity (time) to do it.
" but I like to see things happening! "
yaaa, but your chip may not get 'signal' iN the Target Board, and could be 'signal' problem or Power not ON. Have you checked?
