Hello, my Problem ist to Flash the Board. At startup (init ULINK) is comes always Memory mismatch ...
Have anyone a hint to Flash it?
Philipp
Flash the board, what does it mean?
I mean this ...
www.in-wien.com/.../keil.jpg
I've scanned all articles in the Forum and I've the same problem as in
http://www.keil.com/forum/docs/thread6207.asp
I use the private ULINK from a friend and the free µV3 to convince my firm to switch from GCC GNU to Keil. Perhaps I am a Keil fan :-)
Good to hear that, lot of Keil fans around, me too :-)
OK, Click 'OK' then,
I have test it with a original ATMEL Board SAM7-EK and the error comes again.
Sorry, it seems so that GCC/GNU is better.
Are you using the current release of MDK-ARM. The flash algorithms were lately adapted to cover also the EX version of the device.
The compiler has absolutely nothing to do with this.
Yes, I have download it two weeks ago (free-version). If this example runs, so I can buy the full version.
Now it runs with the original ATMEL Board + ULINK, but I can't flash the OLIMEX with the SAM7X.
MDK 3.03 contains an example in the folder C:\Keil\ARM\RV30\Boards\Atmel\AT91SAM7SE-EK\Blinky
This File doesn't exist. I have only this ...
C:\Keil\ARM\RV30\Boards\Atmel\AT91SAM7S-EK
What is RV30?
RV30 stands for RealView 3.0.
You need to download the current version MDK 3.03a.
