STR7 external interrupt
I'm using a STR710FZ2 uC with an external adc. When conversion is ready, the adc toggles a pin low which is connected to P1.11.
I want an interrupt to be generated on the falling edge of P1.11 so the adc value can be read.
As far as I can see I've initialised the XTI and the EIC correct, but it doesn't seem to work.
Any suggestions?
Here is some of my code.
**  INIT ADC
void init_adc(void)
 config_gpio_port(PORT_1, 0x0001 << EXAD_DOUT,   GPIO_INPUT_PP );
 config_gpio_port(PORT_1, 0x0001 << EXAD_DREADY, GPIO_INPUT_PP );
 write_gpio_pin(  PORT_1, EXAD_SCLK, FALSE);
 write_gpio_pin(  PORT_1, EXAD_DIN,  FALSE);
 config_gpio_port(PORT_1, 0x0001 << EXAD_SCLK,   GPIO_OUTPUT_PP);
 config_gpio_port(PORT_1, 0x0001 << EXAD_DIN,    GPIO_OUTPUT_PP);
 /* disable external interrupt, active on falling edge of IN_ADC_BUSY    */
 config_interrupts(DISABLE);
 config_irq_channel(IRQ_CHANNEL_XTI, DISABLE);
 XTI->PRH  = 0x00;
 XTI->PRL  = 0x00;
 XTI->MRH  = 0x00;
 XTI->MRL  = 0x40;
 XTI->TRH  = 0x00;
 XTI->TRL  = 0x00;
 XTI->CTRL = 0x00;
 XTI->CTRL = 0x02;
 config_irq_channel_priority(IRQ_CHANNEL_XTI, IRQ_PRIORITY_XTI);
 config_interrupts(ENABLE);
**  ADC ISR
void external_adc_interrupt(void) __arm
  unsigned int adc_value;
  line_value = XTI_InterruptLineValue();
  XTI_PendingBitClear(line_value);
  value = read_external_adc_value();
** Peripherals IRQ Handlers Address Table
PUBLIC          IRQ_Vectors
IRQ_Vectors:
T0TIMI_Addr:    DD      timer_interrupt?A
FLASH_Addr:     DD      FLASHIRQHandler
RCCU_Addr:      DD      RCCUIRQHandler
RTC_Addr:       DD      RTCIRQHandler
WDG_Addr:       DD      WDGIRQHandler
XTI_Addr:       DD      external_adc_interrupt?A
USBHP_Addr:     DD      USBHPIRQHandler
I2C0ITERR_Addr: DD      I2C0ITERRIRQHandler
I2C1ITERR_Addr: DD      I2C1ITERRIRQHandler
UART0_Addr:     DD      uart_isr?A
UART1_Addr:     DD      uart_isr?A
UART2_Addr:     DD      uart_isr?A
UART3_Addr:     DD      uart_isr?A
BSPI0_Addr:     DD      BSPI0IRQHandler
BSPI1_Addr:     DD      BSPI1IRQHandler
I2C0_Addr:      DD      I2C0IRQHandler
I2C1_Addr:      DD      I2C1IRQHandler
CAN_Addr:       DD      CANIRQHandler
ADC12_Addr:     DD      adc_isr?A
T1TIMI_Addr:    DD      T1TIMIIRQHandler
T2TIMI_Addr:    DD      T2TIMIIRQHandler
T3TIMI_Addr:    DD      T3TIMIIRQHandler
                DD      0                   ; Reserved
                DD      0                   ; Reserved
                DD      0                   ; Reserved
HDLC_Addr:      DD      HDLCIRQHandler
USBLP_Addr:     DD      USBLPIRQHandler
                DD      0                   ; Reserved
                DD      0                   ; Reserved
T0TOI_Addr:     DD      T0TOIIRQHandler
T0OC1_Addr:     DD      T0OC1IRQHandler
T0OC2_Addr:     DD      T0OC2IRQHandler
