I'm programming with Keil since 2 months and until now I've never had a problem. But now the JTAG connection for my XC164CM does not want to work.
These are the error requests I get, when I want to change something in the DAS Debug Settings:
1. Error accured during device access
2. DAS Port is in wrong state
I also recognized that when I plug in the whiggler the microcontroller is been reseted (the reset LED burns).
Hope someone can help me!
I just have a simelar behaivoir. Some times on connecting for a debug sesion it won't work. It didn't help to reset the target or unplug and replug the usb-wiggler. Just rebooting of the pc helped. Has somone more experience?
Are you using ULINK or some other debug adapter?
I'm using USB-Wiggler from Hitex wit Infineon's Device Access Server (DAS). Yesterday I was abel to start debuging. I Programmed the Flash over J-Tag an then trayed to load the Software on pressing the debugg button. First tray it allways faild. With a second tray it mostly worked. With the ULink it just didn't worked out.
