Is there a data type larger than an unsigned long in keil MuVision compiler?
if so, how do i use it?
im needing about a 64 bit variable
oops, i guess theres no such compiler as MuVision... im using uVision
sorry if i confused anyone
Is there a data type larger than an unsigned long in keil MuVision compiler well, I could look it up in the manual for you, but why do you not do so yourself. Ther5e even is an entry "data types" in the ondex.
"theres no such compiler as MuVision ... im using uVision"
And that still isn't a compiler - it's the IDE!
The compiler is C51.
http://www.keil.com/support/man/docs/uv3/uv3_ov_swdevcycle.htm
No But if you look (google) you can find code for 64 bit variables. Or you can write it you self.
