We are using 80186 intel core for our existing application.Our code size is 20k.We want upgrade our product performance.so we want to go for ARM7/ARM9.what will be the code size .will it increase or will it be same.what are the advantages when compared to both. Regards Anuradha.
How long is a piece of string?
I can answer that:
from one end to the other :)
In this case, it could be an ARM's length...? ;-)
..it could be an ARM's length...
It could. And if you wanted it a bit shorter, it could cost you ARM and leg. :-Q Yes. End of summer, nothing to do, just to make fun from an innocent by-standers, hm?
<chuckles>
Smart guys, I have one for ya: What are the upper and lower tolerance bounds of 5% zero Ohm resistor, hm? Lemme see: 1 percent is....
