hello frens i am very new to 8051 .please suggest me the small scale project that i can undertake in my college workashop . but it should consist of following things 1. some sensors,adc,dac 2. it should be interfaced with my desktop computer
suggestions r invited
pls also guide me with one small thing i want my end output to be some grapical i.e. contains sm graph so for this i hv to develop a software besides my assembly language programming
hey iam also very new to this 8051 but iam under a training in my company so i think i can help u go for some sample codes such as adc inputs and have theshold value to show some LED outputs
thnx for helping me out so can u give sm idea i hv sm compulsory big things to do in my university u can also contact me at
Nishanshah2381@gmail.com
OMG, duz ur unvrsty gv pssng gr8s 4 wrytng lik tht?
See u can have a automation of lab or something.some small programs which controls the temperature of ur lab use c51 for getting temperature from one analog device via ADC pass it to one Coinstrain so if it above than that constrain go for a pin to low as output using that pin triger switch on the cooler if the temperature is reached means make the pin to default so that the Cooler is switched off first try this by simulator. this will give the basic idea of c8051 use seperate driver functions for getting values from ADC.
A dictionary will be required to figure the above post out and, after much effort, i figured it out. So to save the rest of the participants from the same effort I will present my findings:
thnx thanks for helping me out so can u you give sm some idea i hv have sm some compulsory big things to do in my university u you can ....
hope this saves some of you the effort.
PS I wonder if he turns in his coursework in gobbelygook or is that only when he ask for help
