bit setting, how to
Hallo!
I'm searching for a explanation for the code in Keil's CAN.h
(01=set; 10=reset)
<-------------code------------->
#define NEWDAT_ 0x0200u
#define CPUUPD_ 0x0800u
#define TXRQ_ 0x2000u
#define NEWDAT_CLR (~NEWDAT_)
#define CPUUPD_CLR (~CPUUPD_)
#define TXRQ_CLR (~TXRQ_)
#define NEWDAT_SET (~(NEWDAT_ >> 1))
#define CPUUPD_SET (~(CPUUPD_ >> 1))
#define TXRQ_SET (~(TXRQ_ >> 1))
For example, this statement clears (resets) the CPUUPD flag and sets the NEWDAT and TXRQ flags, while leaving all the other flags unchanged:
CAN_MSGOBJ[can_object_number].msg_ctl
= CPUUPD_CLR & NEWDAT_SET & TXRQ_SET;
<-------------/code------------->
(How) does it work (leaving all the other flags unchanged)? Has it something to do with the u or what does the u stand for?
I know bit manipulation/masking in the way
bitfield = bitfield | (0x2); //set bitfield[1]
bitfield = bitfield & ~(0x2); //clr bitfield[1]
Thanks Sven.
