C51 v8.00 can be installed with floating licenses instead of single user licenses. The "Licensing" manual states that uv3 automatically obtains licenses as needed. We often don't use uv3, but instead jam to build our projects. Is there a command-line way to grab a floating license so that the compiler, etc. can run without invoking uv3?
The compiler will automatically obtain the license when needed.
