I have downloaded and installed the driver: http://www.keil.com/download/docs/119.asp I also have installed uv3 and the C51 tools I can compile and run C51 programs in simulation mode, but I am not able to run it using Hitex MX51 ICE emulator. Does anybody know a step by step procedure to setup uVision project with Hitex MX51? Do I need also a version of HITOP-8051 be installed or the driver and the uVision IDE is sufficient? Should I use older version of uVision such as uv2 or using uv3 is OK? Thanks
You should contact Hitex, since this driver is a product of Hitex.
