hi! i tried buliding target in keil in assembly language and it gave a cryptic error.. can anyone help me figure out how to build target or run a assembly language written code in keil... i can well do it in C but unable to figure it out using assembly.... Thanks.
You haven't said which product you're using, or what error you're getting, so it's impossible to say! Have you looked in your Examples folder...?
hi! thanks for assistance.. i used * STARTUP.S: Startup file for Philips LPC2000 and then th source file contained a very simple programme: TTL ch4ex1 - move16 AREA Program,CODE,READONLY Main LDRB R1,Value STR R1,Result SWI &11 Value DCW &C123 ALIGN Result DCW 0 END and th error i found was : undefined symbol _main(referred frm startup.o) indefinrd symbol _use_two_region_memory (referred frm startup.o) target not created. as far as the question of product is concern ...i m unable to makle out what u wannna know... i m goin to burn one of the arm philips LS series......... and to cret .exe n other linking i m tring to use KEIL microversion3 arm development tool kit ....which i dowmloded frm http://www.keil.com free of cost...
i m goin to use ARM tools.....
