Debugging bootloader + application ?
I have a question on how to debug an application that consists of two separate projects - namely a bootloader+firmware upload part and the actual application - that runs on an ADuC845.
The bootloader will be located in the memory area 0xE000-0xF7FF, the application in 0x0000-0xDFFF.
Unfortunately, the emulator erases the complete code memory when loading a file to debug, so it is not possible to load the application, then the bootloader, and then debug the bootloader with the application in place.
Can I use the hex2bin/bin2hex utilities to merge the two hex files and start debugging ?
Regards,
Christoph
