How to get PC-Lint to work in uVision
I am using uVision 3.00 for ARM with the Realview compiler.
I want to integrate PC-Lint 8.0 from Gimpel software. However when I try this I can't seem to get it to work.
I've entered the correct lint executable and I've entered the correct config file, but the output window only shows:
Running PC-Lint...
after that nothing, but I'm sure PC-Lint is executed. In a command window it works fine too. When I use Customize Tools it opens a command window quickly and gone again, but nothing in the Output window.
Can someone help me with this?
  • Problem "solved" again, after I compiled again I noticed there weren't any Error or Warning messages in the output window either, only the files it compiled.
    This is strange, so I rebooted my entire system (restarting uVision did not help) and the output window worked again for compiling and suddenly for PC-Lint as well.
