We have a design that uses function pointers and sometimes the parameters passed to a "C" routine are not used. Thus we get alot of compiler warnings. Is there any way to remove these warnings? Previous versions of the compiler did not raise these warnings.
This is an eternal problem - especially in the type of situation you describe. There are various tricks, none of which is universally applicable to all compilers. :-( eg
void fn( int unused1, unused2 ) { unused1; // dummy reference to unused1 unused2 = unused2; // dummy reference to unused2 }
I recommend defining a macro so that you can change implementation as needed between compiler versions or different platforms.
#define UNUSED(arg) if(arg){} void f (int a) { UNUSED(a); }
void f (int a, int /*b*/) { }
