hi sir i need one help now iam doing project on 89c51 using C51 Evaluation Software i converted 0-5 analog volatge to 0-5 digital voltage . now i want convert digital data to pressure my output should be like this 0v 1.1E-1 3v 4.1E-4 0.1 1.2E-1 4v 5.1E-5 1v 2.1E-2 5v 6.1E-6 2v 3.1E-3 i want 500 values in between 0 to 5 volts how to calibrate the voltage interms of preesure what logic i want use to convert Voltage to pressure my C51 not taking floting oparations please help regards chandra sri
Hello, this is Swananda from India. Couls you please help me by sending on how to program the 89C51 in C/C++ to interface the At24C04(External Memory).
if you do not like the replies, do you really think you are going to get something more to your liking by posting in unrelated threads?
Iam sorry sir i can not spot your mistake please give solution for that one thank you sir
It's a classic 'C' programmer's mistake! You need to learn to spot these things if you want to do 'C' programming! (it's the kind of thing you'd get in a 'C' test at a job interview!) Another hint: what's the difference between a char and a string in 'C'? Don't be afraid to look in your 'C' textbook... (they probably won't let you do that in an interview, though!)
Have you given up? Try
char * pressure_string[] =
hi sir thank you sir i tried this program { unsigned int voltage; unsigned char *pressure_string[] ={"11E-1","12E-2","13E-3"}; printf( "Voltage %u mV = Pressuse %s", voltage*10, pressure_string[voltage] ); } it is showing folling out put "voltage 10mv=pressure 13E- " it is not showing full value. regards nari
When you posted your data as
0.00v =1.1E-1 0.01v =1.2E-1 0.02v =1.3E-1 . . 1.00 =2.1E-2 . . 2.00 =3.1E-3 . . 3.00 =4.1E-4 4.00 =5.1E-4 5.00 =6.1E-5
char * pressure_string[] = { "1.1E-1", // Index 0 corresponds to 0mv "1.2E-1", // Index 1 corresponds to 10mv "1.3E-1", // Index 2 corresponds to 20mv : : }
{ unsigned int voltage; unsigned char *pressure_string[] ={ "11E-1", "12E-2", "13E-3" }; printf( "Voltage %u mV = Pressuse %s", voltage*10, pressure_string[voltage] ); }
printf( "Voltage %u mV = Pressuse %s\r\n", voltage*10, pressure_string[voltage] );
Hi sir I assign a value to 'voltage' now iam geting correct values. up to 24 string elements [array elements]it showing correct. Above the 24 elements it is compiling but it is showing linking error the error is: "Build target 'Target 1' linking... *** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: DATA SEGMENT: _DATA_GROUP_ LENGTH: 0071H Program Size: data=123.1 xdata=0 code=1559 Target not created*/" above the 50 elements it is not compiling and showing this error . the error is: " compiling forum.c... MAIN\FORUM.C(19): error C241: 'main': auto segment too large main\forum.c - 1 Error(s), 0 Warning(s). " regards chandu
*** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: DATA This means that there is not enough memory available in DATA memory space to hold all the variables you have declared. Which is not surprising, as the 8052 only has 128 bytes of DATA memory. Since your programm will most likely not change the contents of the string array at run-time, you could simply store the array in CODE space instead. If the program does need to change the contents, and your device has enough XDATA memory, store the array there instead. Refer to the Cx51 manual for more information on memory types and areas: http://www.keil.com/support/man/docs/c51/c51_extensions.htm
Chandra, Is it just that English is not your first language, or do you really not understand the word "OVERFLOW" ? See: http://www.keil.com/forum/docs/thread7364.asp As Christoph says, the data in the lookup table is constant - it will not change at run-time - so you should put it into CODE space. You might find that you exceed the code space limit of the evaluation version, though...
thank you sir thank you for your valueble answers Hear in my project iam using 4 seven segment display for to display the pressure. up to now iam displaying the pressure on the serial window. pleace tell how to display the data on 7 segment display with out using printf statement. Because printf is taking lot of memory . regards chandu
"in my project iam using 4 seven segment display for to display the pressure." Do you mean a four-digit 7-segment display? If so, how do you plan to display, for example, "4.1E-4" on four 7-segment digits:
4. = 1st digit 1 = 2nd digit E = 3rd digit - = 4th digit 4 = Oops! no more digits!!
Textbook time, again! Andy, do not come to the US, we have laws against cruel and unusual punishment :) Erik
we have laws against cruel and unusual punishment Textbook time may be cruel, but it is certainly not unusual, and therefore perfectly fine. :)
"Textbook time ... is certainly not unusual" It seems to be becoming increasingly unusual amongst today's students... :-(
