Can a software memory management unit be implemented on a 8032 microcontroller ?
Why would you want to do that? Exactly what functionality do you want from this "memory management unit"? Try a search for "malloc" and "dynamic allocation" in relation to the C51 tools, and see all the previous discussions on this topic!
My project is on a MP3 player whose code size is 116kByte which is stored in a Nand Flash chip. Upon boot up, I would like to get only 32kB of 116kB into 8032's Program memory which is implemented as SRAM of size 32KB. I want to implement paging mechanism for getting 32KB blocks into 8032's PM as 8032 has no MMU support. So, i would like to know whether the same can be implemented on a 8 bit microcontroller.
"You too, eh? ... Is this a class project?" Ah no, this is the one I was thinking of: http://www.keil.com/forum/docs/thread7324.asp So why did you start a new Thread on the same question?
nope, 2 Mbyte 16 Mbit http://www.sst.com/products.xhtml/parallel_flash/39/x8/SST39VF1682 Ok, it is not $2 it is $2.63 Erik
In theory, I'm sure you could run an MMU with an 8051. In practice, a typical MMU implementation is huge compared to the entire 8051. (The ARM7 MMU, for example, is about the same size as the ARM7 core plus its instruction and data caches.) I doubt anyone ever built an 8051 derivative with an MMU. It wouldn't make much sense. Given the gate count of the MMU, you might as well go ahead and make the processor core larger. Sounds more like you want to overlay code. The usual 8051 banking mechanism would do. You'd write custom banking routines to copy the new bank into SRAM. Performance will be very slow, so you'll need to be very careful to organize your program in relatively discrete overlays that interact very little. I wouldn't expect you could afford to copy 16KB of data on every function call.
Hi Neil, Iam using a SOC with an inbuilt 8032 and DSP. Currently, it is running an MP3 application and definitely code banking is done. My client wants me to design the application such that only 32kB code is executed at a time. He wants to replace the 8032's 128kB SRAM with a 32KB SRAM in his future design. So, that's the task.
Sorry Neil, Previous thread responses were more related to code banking. Since, code banking won't work for the design Iam in search of, i thought maybe I would get help on implementing the same using MMU concept.
HI Erik, My client has already designed the hardware for the same. So, iam in search of a design to get only 32kB into 8032's PM at a time. Can mmu concept be implemented to do realize the same ? Kindly suggest a method.
Hi Drew, Is it possible to do software implementation of MMU on a 8032 microcontroller, as there is no option in hardware.
"My client has already designed the hardware for the same." Oh dear! You need to alert them that it may not be suitable! "So, iam in search of a design to get only 32kB into 8032's PM at a time." You are going to have to look in detail at the operation of code banking. This is described in the Compiler & Linker manuals; also search the Knowledgebaase. Instead of just flipping a few bank-select lines to make an out-of-bank call, you will have to: 1. re-map your "banked" PM area from the 8032's CODE address space into its XDATA address space; 2. load code from the NAND flash into the XDATA-mapped "banked" PM area; 3. map the "banked" PM area back into the 8032's CODE address. Obviously, this will have a serious impact on your performance!
HI Neil, Code banking concept will not work out for this design nor will 1. re-map your "banked" PM area from the 8032's CODE address space into its XDATA address space; 2. load code from the NAND flash into the XDATA-mapped "banked" PM area; 3. map the "banked" PM area back into the 8032's CODE address." We have only 16KB as data memory for 8032. So, can the mmu software implementation be done on an 8032 controller.
So, can the mmu software implementation be done on an 8032 controller. Yes, it can be done. In theory. However, the external memory must be connected so it can be mapped to both external xdata and external code memory space, since there is no way to write directly to code memory. This is a hardware design consideration - if it is not already wired accordingly in your hardware, and you have no way of changing the hardware, then you might find yourself out of luck. Also, it is going to be slow. In order to be useful for anything (apart from proving that the concept works), careful consideration is necessary on where to locate the programs functions in order to minimize the amount of swapping.
To page the memory, I'd use the same mechanism as for banked code. Rather than having the bank switch routines update a simple register as they would normally do, though, the custom "banking hardware" update routines that you write will do the paging instead. A call to a routine in a different bank thus jumps to the common bank, copies the new page into RAM, and then jumps to that routine that is now present in RAM. The page copy will be very slow, so you want to avoid calls to different banks where at all possible. Hopefully your program can be organized into highly independent phases of operation, so that you change these pages or overlays rarely. You could roll your own paging mechanism from scratch, but then you'll have to struggle with the linker to get it to understand that several blocks of code will be intentionally overlaid at the same address range. Telling the linker that the code is banked seems like an easy way to avoid that struggle. But you could also use the linker directives to manually assign addresses to all of your code segments. (I don't know without trying it whether you can force it to accept the conflicting address assignments and link the file anyway.) A hybrid scheme is to write the code as though it were banked, but have a null implementation for the actual bank switch routines. Paging would be done manually, with explicit calls inserted into the code. You'll save a little overhead on each function call this way (that which checks to see if the current bank is the one you need). But as soon as you accidentally call a function that's not really in the same bank as you have loaded, the code will go crazy. It'd be a lot safer to route all function calls through the bank switch routines to check, and perhaps add debug code to notify you when banks changed, so you can make sure it only happens when you expect.
Chetan Prabhu said: "Code banking concept will not work out for this design" Why not?? Drew Davis made the same suggestion: "To page the memory, I'd use the same mechanism as for banked code. Rather than having the bank switch routines update a simple register as they would normally do, though, the custom 'banking hardware' update routines that you write will do the paging instead." What is it about this approach that "will not work" in your system? If this can't work, what wil??
"1. re-map your 'banked' PM area from the 8032's CODE address space into its XDATA address space; 2. load code from the NAND flash into the XDATA-mapped 'banked' PM area; 3. map the 'banked' PM area back into the 8032's CODE address." If this will not work in your system then the answer to your question is simple: you cannot implement your MMU! You do realise, don't you, that the 8032 architecture has completely separate & distinct CODE and XDATA address spaces? The 8032 architecture has no instructions to write to its CODE space, and it cannot execute code from its XDATA space. Therefore, if you want to load stuff into SRAM, that SRAM must be mapped into the XDATA address space, and if you want to execute that stuff it must be mapped into the CODE address space. So, either you have to be able to switch it between the XDATA and CODE address spaces, or it must be permanently mapped into both address spaces
The operation of the standard bank switching code is described in the comments in the standard L51_BANK.A51 file:
; THEORY OF OPERATION * ; ------------------- * ; The section below describes the code generated by BL51 or LX51 and the * ; operation of the L51_BANK.A51 module. BL51/LX51 generates for each * ; function that is located in a code memory bank and called from the common * ; area or a different code bank and entry into the INTRABANK CALL TABLE. The * ; INTRABANK CALL TABLE is located in the SEGMENT ?BANK?SELECT and listed in * ; the Linker MAP file. The entries in that TABLE have the following format: * ; * ; ?FCT?1: MOV DPTR,#FCT ; Load Address of target FCT * ; JMP ?B_BANKn ; Switch to Bank and Jump to Target Code * ; * ; Instead of directly calling the function FCT, the Linker changes the entry * ; to ?FCT?1. This entry selects the bank where the function FCT is located * ; and calls that function via the routines defined in this L51_BANK.A51 file. * ; The L51_BANK.A51 file contains two sets of functions for each bank: * ; * ; ?B_BANKn is a routine which saves the entry of the ?B_SWITCHn function * ; for the current active bank on the STACK and switches to the * ; bank 'n'. Then it jumps to the address specified by the DPTR * ; register. It is allowed to modify the following registers in * ; the ?B_BANKn routine: A, B, R0, DPTR, PSW * ; * ; ?B_SWITCHn is a function which selects the bank 'n'. This function is * ; used at the end of a user function to return to the calling * ; code bank. Only the following registers may be altered in the * ; ?B_SWITCHn function: R0, DPTR * ; * ; The current active bank is stored in ?B_CURRENTBANK. RTX-51 uses this * ; variable to restore the code bank after a task switch. To get correct * ; results, ?B_CURRENTBANK must be set to the code bank before the hardware * ; switch is done, or the code banking sequences must be interrupt protected. *
; The way the code banking works is pretty remarkable. When your program ; calls a function that is known to be accessible by another bank (even if ; the called function is in the same bank), instead of jumping directly to ; that function, the LCALL instruction instead jumps to a table that the ; BL51 creates. (Note: the LCALL does push the return address into the ; stack.) The table moves the called function's address to DPTR, then ; jumps to the ?B_BANKn (where n is bank number that the called function ; resides in). There, the program determines if the bank that the called ; function resides in is the same as the current bank. If so, it jumps to ; the address in DPTR. If not, it's going to need to switch banks, so it ; pushes the address of the SWITCH code needed to return to the current ; bank after the called function completes. It then pushes the address of ; the called function (from DPTR). It then jumps to SWITCHn (where n is ; the bank number that the called function resides in.) SWITCHn switches ; banks by writing to the code mapper and updating ?B_CURRENTBANK and then ; returns (which jumps to the address indicated by the top two bytes in the ; stack-- the called functions address!) The called function does its ; business and then returns (which jumps to the address indicated by the ; next two bytes in the stack-- the code to return to the caller's bank!) ; The program then switches back to the original bank and returns again, ; which brings us back to the proper location in the caller function. ; ; The amazing thing about the code banking library is that if the called ; function calls another function that requires a bank switch, all the ; proper return addresses are retained on the stack, in the proper order. ; So returning after multiple bank switches is handled correctly. The ; other amazing thing is that all the code banking is handled using only ; two registers, DPTR and the accumulator(A/ACC). Note: The fine people ; at Keil Software developed the algorithm; Triscend merely modified it ; to switch banks using the code mapper.
"What more could you want?" What'd be really useful would be a hardware DMA unit to do the actual loading of the page...
You are going to need some code in ROM to boot this thing and load the first page. How will that be handled?
