There is a BUG in the compilation of a bit definition:
unsigned int bdata my_int; sbit bit15 = my_int ^ 15; sbit bit7 = my_int ^ 7; void main() { my_int = 0x8000; if(bit15) { // Here we shall not appear,as compiller // will be erroneous to check 7-bit of // a variable my_int instead of 15-bit // (as this variable place in memory in // little endian order) // ... } if(bit7) { // oops! we here! // ... } }
Post the generated assembler?
I have found such note in the C51 manual: ------------------------------------------- "The sbit data type uses the specified variable as a base address and adds the bit position to obtain a physical bit address. Physical bit addresses are not equivalent to logical bit positions for certain data types. Physical bit position 0 refers to bit position 0 of the first byte. Physical bit position 8 refers to bit position 0 of the second byte. Because int variables are stored high-byte first, bit 0 of the integer is located in bit position 0 of the second byte. This is physical bit position 8 when accessed using an sbit data type." ------------------------------------------- That only people will not think up to explain the absurds!
That only people will not think up to explain the absurds! it is crystal clear from your post that you have refused to even glance at the '51 architecture. Had you done so, the explanation would have been crystal clear. Well, since you refuse to study the '51 architecture, one comment Good luck, you will need it Erik for your sake I hope I'm wrong.
Do not stir bosh. Speak to the point. I have studied '51 architecture at once as soon as it has appeared. As it is the one-byte controller all other "wide" types of data are added by C-compiler. So C-compiler knows as data place in memory and it can take the necessary byte and to analyse necessary bit. I have declared the integer (16-bits) and I want at it 14-th bit. Instead of it I for some reason should read any ridiculous explanations and specify 6-bats. Unless it not absurdity?
